It is currently Wed Aug 20, 2025 4:03 pm
 Post subject: Air compressor problem
PostPosted: Sun Mar 02, 2014 5:01 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
After a little trouble shooting I took apart the switch and found this...I've emailed the company complaining about the Shyt wiring and that I'm lucky the shop didn't burn down. However, if I hard wire (bypass the switch) will the pressure kill still work when it reaches the set threshold? Or is it more like setting a bomb in my shop if not monitored while pressure builds?
First name: Joey
Last Name: Holliday
City: Palmetto
PostPosted: Sun Mar 02, 2014 5:02 pm
First name: Joey
Last Name: Holliday
City: Palmetto
PostPosted: Sun Mar 02, 2014 5:24 pm
First name: Joey
Last Name: Holliday
City: Palmetto
My take is that this is just the on- off switch. If it's on the compressor regulator works and it cuts out at the set threshold. SO hard wiring it should only make it ON- all the time, unless unplugged. Which case the pressure regulator should still work. After all this switch is merely a connection to complete the circuit- 4 wires, 4 contacts. One of the contacts is fouled, that's it. If anyone can give me a reason not to hard wire it, please say so. Safety is important.
PostPosted: Sun Mar 02, 2014 6:07 pm
State: Tennessee
Adjustable pressure switch. controls max pressure (shuts off) and minimum (starts up) Don't hard wire your compressor your gonna break something duh
PostPosted: Sun Mar 02, 2014 6:22 pm
First name: tim
Last Name: minkkinen
City: charlotte
State: nC
Zip/Postal Code: 28203
Country: united States
It's the pressure regulator switch. You can probably find a universal replacement with a google search. About $25. Tim
PostPosted: Sun Mar 02, 2014 10:49 pm
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
Some compressor packages have redundant systems, some don't. It is usually based on the cost of the unit and whether or not the company has had to pay off after someone bypassed a safety device and the thing blew up.
In a past life, I worked on air compressor design, and part of my job was to analyze failures. Compressors, tanks, and systems are bombs. Never bypass a safety feature. By a new switch, if necessary buy a new regulator. But don't hard wire it.
Phil
http://www.oleninstruments.com
"Those who tilt at windmills are only considered insane by those who can't see the dragon."
PostPosted: Mon Mar 03, 2014 12:13 am
Last Name: Hammond
Do not wire it straight thru!
W. W. Grainger has dozens that will work-
http://www.grainger.com/product/CONDOR- ... s_pp=false
Might take a while to choose one though...
Mikey
The Biggest Little City, Nevada
www.hammondguitars.com
I love building guitars!
Users browsing this forum: Bing [Bot] and 10 guests
